[quote=Trebor post_id=360507 time=1545465257 user_id=18997]
[quote=Pikamon101 post_id=360384 time=1545345872 user_id=240227]
https://www.mediafire.com/file/od8769f3 ... s.mp3/file [/quote]
That doesn't sound like raw recording : some processing has been applied, e.g. frequencies above 4kHz have been attenuated.
If you didn't deliberately do that processing, have a look in Windows sound and [url=
https://www.thewindowsclub.com/disable- ... windows-10]disable [u]all[/u] enhancements[/url], in both the recording & playback tabs.
Applying this [url=
https://manual.audacityteam.org/man/equalization.html]equalization[/url] "curve" improves that processed recording ...
RugRats.xml
[quote=Pikamon101 post_id=360321 time=1545252806 user_id=240227]
... level the volume ...[/quote]
At times you're moving out of the mic's sensitivity zone.
AT2020 has a cardioid, not omini-directional, sensitivity pattern,
i.e. There is a right way to position the AT2020 , (and many wrong ways).
[img]
http://media.bestquestions.com/bestques ... x808px.jpg[/img]
[/quote]
Hi!
Thanks for the reply!
Unfortunately I imported the Rugrats.xml file on the Equalization Tab on Audacity and it didn't really fix anything...
Also the problem was I was reading my script and I kept moving left and right so I could read it and I made the mistake of putting my Microphone on my left side.
Is there a way to fix the recording or should I just re-record the whole entire thing?
Merry Christmas and have a great day and God bless!
