convert wav to mp3 - solved
jack magee
Operating System: Windows 7
Post by jack magee » Sat Dec 08, 2018 7:15 pm
Audacity 2.2.2
I have 99 .wav files and want to convert all to .mp3. I tried opening all of them and a new Audacity opened for each one. I stopped it at five. How do i do this please
OK figured it out
waxcylinder
Re: convert wav to mp3 - solved
Post by waxcylinder » Sat Dec 08, 2018 10:48 pm
Use File > Import not File > Open
