Exporting a 24-bit file to wav
JJ2106
Operating System: Windows 7
Post by JJ2106 » Thu Dec 06, 2018 10:18 am
Hello,
I'm new to this forum.
I have Windows 7 and Audacity 2.3.0
My problem is this: when opening a 24-bit file, then exporting it to wav, the file is systematically recorded as 16-bit (whatever the sampling frequency is).
I tried to modify Edit > Preferences > Quality, to no avail.
Any idea/info is welcome.
Thank you
Jean-Jacques
Trebor
Re: Exporting a 24-bit file to wav
Post by Trebor » Thu Dec 06, 2018 11:38 am
When exporting audio, chose "other uncompressed files", then you get a menu with the 24-bit WAV option ...
If you want to save as 24 bit WAV.gif (46.74 KiB) Viewed 136 times
[ I don't think you have to install ffMPEG to get those WAV encoding options :?: ]
Post by steve » Thu Dec 06, 2018 12:53 pm
I can confirm, you don't. 24-bit WAV is natively supported by Audacity in the way described in your post.
JJ2106
Post by JJ2106 » Thu Dec 06, 2018 1:23 pm
Thank you both,
In my case, it is as simple as selecting Signed 24bit PCM.
I don't know how I possibly overlooked this!!
Kind regards,
Jean-Jacques
waxcylinder
Post by waxcylinder » Thu Dec 06, 2018 2:35 pm
Yes, we added that directly to that drop-down list to make it easier to find.
In earler versions if Audacity the only way was the one that Trebor showed you - and a lot of folk found that difficult to discover.
JJ2106
Post by JJ2106 » Sun Dec 09, 2018 11:37 am
Thanks, Waxcylinder,
Another 2 questions:
- would it be possible to save Export parameters from one session to another, in order to avoid errors?
- would it be possible to Export to Flac, in order to save transcoding time?
Thanks again,
J-J
Trebor
Post by Trebor » Sun Dec 09, 2018 12:56 pm
A 24-bit FLAC will take 2x-4x* as long to encode as a 24-bit WAV.
The former employs lossless-compression, the latter is uncompressed.
[ * depending on the level of compression selected ]
JJ2106
Post by JJ2106 » Sun Dec 09, 2018 1:40 pm
Yes, Trebor, this is correct.
But off-line transcoding will take just as much time.
Hence my question.
J-J
waxcylinder
Post by waxcylinder » Sun Dec 09, 2018 2:17 pm
Audacity should be "rembering" those for you and restoring them on next usage even in a changed session.
JJ2106
Post by JJ2106 » Sun Dec 09, 2018 4:11 pm
Exactly!
J-J
