Cutting and Copying Files
chuman
Post by chuman » Wed Dec 05, 2018 11:27 pm
when i try to highlight a section of a file the middle doesn't highlight. makes it a little harder to select for copying
Accapella End Of Eternity 12_5_2018 5_20_21 PM.jpg (58.76 KiB) Viewed 50 times
Re: Cutting and Copying Files
Post by steve » Wed Dec 05, 2018 11:58 pm
You have accidentally switched to the "Multi-tool". To switch back to the normal "Selection Tool", press F1, or click the button with the I-beam cursor icon (see: https://manual.audacityteam.org/man/tools_toolbar.html)
