dlls problem
Re: dlls problem
Post by steve » Wed Dec 05, 2018 9:47 pm
I don't know if this will still work as Microsoft ended mainstream support for Windows 8.1 last January, but you could try: https://www.lifewire.com/download-updat ... -1-3506864
DOOMSHOP
Re: dlls problem
Post by DOOMSHOP » Wed Dec 05, 2018 10:34 pm
there are no current updates available :/
DOOMSHOP
Re: dlls problem
Post by DOOMSHOP » Wed Dec 05, 2018 11:12 pm
ok i fixed it i just downloaded an older version of audacity aka version 2.2.1 :D
Re: dlls problem
Post by steve » Wed Dec 05, 2018 11:52 pm
Using an old version was going to be my next suggestion, but NOT version 2.2.1.
A bug has been discovered in Audacity 2.2.1 which can cause data loss if you overwrite the project using "Save Project As..." (rather than the normal ""Save Project...")
Audacity 2.2.1 should be OK so long as you do not use "Save Project As" to update (overwrite) an existing project.
