dlls problem
DOOMSHOP
dlls problem
Post by DOOMSHOP » Wed Dec 05, 2018 7:36 pm
ok so i am getting mad rn so i changed from windows 7 to windows 8.1 pro and i installed audacity i tried launching it, it gave me a dll error i installed that dll and then i get a different dll error i install that one also and another dll error it keeps on going can someone help i don't know how to fix this and i am getting really salty rn :cry:
Re: dlls problem
Post by steve » Wed Dec 05, 2018 8:00 pm
Audacity 2.3.0 requires "Visual C++ Redistributable for Visual Studio 2015 " which may not be present on old Windows systems. You can get it from here: https://www.microsoft.com/en-ie/downloa ... x?id=48145
A reboot may be required after installing this package.
DOOMSHOP
Re: dlls problem
Post by DOOMSHOP » Wed Dec 05, 2018 8:47 pm
thank you but now i am getting this error
Re: dlls problem
Post by steve » Wed Dec 05, 2018 9:02 pm
Audacity is not installed correctly.
Remove all instances of Audacity from your system, then re-download the .EXE installer from: https://www.audacityteam.org/download/ and reinstall by running the .EXE installer.
DOOMSHOP
Re: dlls problem
Post by DOOMSHOP » Wed Dec 05, 2018 9:08 pm
i still get the same error
Re: dlls problem
Post by steve » Wed Dec 05, 2018 9:26 pm
Why is "Program Files (x86)" on your D: drive?
Re: dlls problem
Post by steve » Wed Dec 05, 2018 9:30 pm
Are you using an extremely old computer?
DOOMSHOP
Re: dlls problem
Post by DOOMSHOP » Wed Dec 05, 2018 9:34 pm
uh well no i am using a lenovo laptop i don't know if it's old to be honest
weak specs.PNG (27.92 KiB) Viewed 33 times
Re: dlls problem
Post by steve » Wed Dec 05, 2018 9:34 pm
Is Windows 8.1 fully updated?
DOOMSHOP
Re: dlls problem
Post by DOOMSHOP » Wed Dec 05, 2018 9:35 pm
yes i think it is fully updated how can i check? it doesn't ask me for any updates
