All speaker sounds are echoey
Bear
Post by Bear » Tue Dec 04, 2018 2:24 pm
Hi,
First time user of Audacity, been trying to record sounds coming from the speakers of the PC.
After a bit if trial and error i have set the Audio Host to Windows WASAPI and the Recording device to Stereo Mix (after enabling as a microphone). Whilst this does now record when I click record, all sounds that are coming from the speakers are echoey and therefore useless. This is also the case when I am not using Audacity.
Is there a setting that I am missing as if I turn the microphone off I cant record and if I disable the speakers I cant hear anything or record.
Thanks
Bear
Re: All speaker sounds are echoey
Post by Bear » Tue Dec 04, 2018 2:37 pm
Found the setting.
For anyone else that has this issue, in the microphone properties and the listen tab there is a Listen to this Device checkbox that I unchecked.
Thanks
