hi,
I loaded 2 sets of stereo WAV files into a new Audacity project and upon close inspection, there were several dropouts in the tracks.
Track 1: 3 dropout on the left track
Track 2: 1 dropout on the left track
When searching for a resolution to this problem, i came across the dropout detection setting, which is enabled, but the dropouts weren't marked. I assume they weren't marked because I didn't use Audacity to record the WAVs.
Question: Is there a way to scan a track and look for dropouts?
Thanks,
John
Dropout Detection on WAV Load
[email protected]
Re: Dropout Detection on WAV Load
That's correct - Audacity's drop-out detection is only active during recording.[email protected] wrote: ↑Mon Dec 03, 2018 1:32 pmI assume they weren't marked because I didn't use Audacity to record the WAVs.
If the drop-outs are long enough, you may be able to detect them with "Silence Finder": https://manual.audacityteam.org/man/silence_finder.html[email protected] wrote: ↑Mon Dec 03, 2018 1:32 pmQuestion: Is there a way to scan a track and look for dropouts?
This will only work if the drop-outs created silences that are sufficiently long. Some types of drop-out don't create silences at all, in which case the most effective way is to listen for clicks.
[email protected]
Thank you!
The dropouts were longer than the minimum 0.1 seconds that silence finder allows, so this should be a great approach.
Thanks
John
Thanks
John
