Fixing lines
benjamin73
Fixing lines
My flash got removed from my computer, while my audacity file was open. I'm trying to my podcast through my flash drive unto audacity, and it says "not well formed, line 1039" what should I do?
Re: Fixing lines
I assume that you were recording directly to the flash drive?
Attach the ".aup" file to your reply and we can look to see if recovery is possible.
(See here for how to attach a file to a forum post: viewtopic.php?f=49&t=64936)
