OS: Windows 10 Pro x64 build 17134
Audacity version: 2.3.0
Is there any way to export the macros I've created so I can import them onto another computer?
I've searched the install directory but cannot figure out where user defined macros are stored.
I've also searched audacity help, this forum, audacity faq, general google search. No luck finding any information regarding loading/saving/importing/exporting user-defined macros.
import / export user-defined macros
waxcylinder
Re: import / export user-defined macros
I thinks James is planning to write an Import/Export for Macros at some stage …
But until then there us a workaround.
You should find a Macros folder inside your Audacity settings folder.
On Windows this is C:\Users\<your username>\AppData\Roaming\audacity
you can copy the Macros folder or any macros from within that folder and thus move them to another computer.
Thanks waxcylinder - the workaround worked perfectly!
