Playing along backing tracks
mr_strap
Re: Playing along backing tracks
Post by mr_strap » Thu Dec 06, 2018 8:53 am
Hi steve
thanks for replying.
yes I did that and check the rate of each. both have 16 bit 44100. and I matched to audacity track. 16bit 44100.
track for MP3 (for my backing track): 16bit 44100
track for new track (for recording my guitar) 16bit 44100
still error
Post by steve » Thu Dec 06, 2018 11:23 am
Did you match the "Project Rate" to 44100?
("Project Rate" is in the lower left corner of the main Audacity window)
mr_strap
Post by mr_strap » Thu Dec 06, 2018 5:40 pm
hello steve
yes. I set all to 44100 hz.
but still whenever I click the button it will have an error
mr_strap
Post by mr_strap » Thu Dec 06, 2018 5:50 pm
when I set all of them to same rate (44100)
and then click the record button, the record will start at the end of my MP3. I does not record under the MP3 waveform. I hope I explain in clear way. my apologies.
Post by steve » Thu Dec 06, 2018 6:17 pm
That is normal. To record to a new track, hold down the "Shift" key and click the record button.
Post by kozikowski » Thu Dec 06, 2018 6:41 pm
If you can't get overdubbing to work without an error, it's possible you have a different mismatch than any of the normal ones.
When you overdub, Audacity has to play the backing track to the interface perfectly at the same time it records the new performance. The Solo is a native mono device. It's job in life is to record your single microphone. It has a Stereo variation where you can plug your guitar in, too, but that's not the main mode.
Try setting Audacity to mono and mix down your backing track (temporarily) to mono at 44100. See if that starts working, or also important, if you get a different error.
mr_strap
Post by mr_strap » Fri Dec 07, 2018 2:30 pm
thanks steve and kozikowski.
I press the shift and click the record button and now its working with the backing track. I can see my guitar signal under my mp3 backing track.
thanks for help. appreciate it!
Post by kozikowski » Fri Dec 07, 2018 3:35 pm
There's something wrong about that. I need to do some experimenting. You shouldn't need to do that.
Post by steve » Fri Dec 07, 2018 3:55 pm
In Audacity 2.3.0, by default (there's a preference setting to change this) recording to a new track requires the "Shift" key to be held down.
(In old versions of Audacity, the Shift key had to be held down to "append" record to the same track).
waxcylinder
Post by waxcylinder » Sat Dec 08, 2018 11:09 am
See this page in the Audacity Manual re the preference setting: https://manual.audacityteam.org/man/rec ... ences.html
And this page about Recording: https://manual.audacityteam.org/man/recording.html
