Playing along backing tracks
mr_strap
Post by mr_strap » Fri Nov 23, 2018 12:09 pm
hello,
my set up is:
guitar>focusrite Solo>laptop
I have no problems recording my guitar input in audacity, but when I click record button with MP3 (serve as my backing track), the error is popping. could anyone help me on this problem. this is my first time to use audacity.
i already match the input/output of my device and also trying the microphone privacy settings. but still in can not play along with my MP3.
Re: Playing along backing tracks
Post by kozikowski » Fri Nov 23, 2018 7:36 pm
It would be good knowing exactly what the error said, but Overdubbing usually fails because the Audacity Record and Playback settings both have to be set, correct and match. No fair having one at 44100 and the other at 48000, for example.
mr_strap
Post by mr_strap » Sat Nov 24, 2018 5:36 am
hi
the MP3 (my backing track I like to play along) is 44100 while the new track (which im recording) is in 48000. overdub is already check and the device is matching with my focusrite still the below error is appearing.
the error is: UNANTICIPATED HOST ERROR.
and whenever I click "OK"
another error will pop up: ERROR OPENING RECORDING DEVICE. ERROR CODE: 0 SUCCESS"
mr_strap
Post by mr_strap » Sat Nov 24, 2018 5:46 am
i already match the rate to 44100 but still no luck.
also in 48000 still no luck
i also tried to add "STEREO TRACK" for my recording track so that it will match to MP3 stereo but still not working. i just downloaded the audacity yesterday version 2.3.0
mr_strap
Post by mr_strap » Sat Dec 01, 2018 4:34 am
any advice regarding this problem?
thank you
Post by steve » Sat Dec 01, 2018 3:08 pm
In the Windows Sound Control Panel, look for the focusrite in both the recording and playback tabs and check what the sample rate is set at for each.
What settings do you have in the device toolbar?
How are you listening to playback? Headphones plugged into the focusrite?
In the "Transport menu > Transport Options", "Overdub" should be enabled and "Software Playthrough" should be disabled - do you have it set like that?
mr_strap
Post by mr_strap » Mon Dec 03, 2018 5:34 pm
hello steve
im using headphone most of the time.
Audio Host: Windows Direct
Recording Device: Line-in Scarlette Solo
Recording Channel: Stereo
Playback Device: Line-out Scarlette Solo
I also check the overdub and uncheck the Software Playthrough
still not working.
Post by steve » Mon Dec 03, 2018 5:40 pm
Plugged in where?
mr_strap
Post by mr_strap » Wed Dec 05, 2018 9:12 am
Hello Steve,
Im plugging my headset and guitar to focusrite. then into USB port of my laptop.
Post by steve » Wed Dec 05, 2018 9:42 am
Did you do that? Did you find the sample rates for the recording and playback devices? What are they?
