I just reinstaled Win 10 and instal audacity.When i press red buton ''Error opening recording device
Error code:0 succes ''
I instaled another recording softvare Wave Pad same issue.
Please help
It won't record when i press red buton
audiolog55
waxcylinder
Re: It won't record when i press red buton
audiolog55
Nothing.Every step that i try fix it it won't record
