24bit Recording XP
davethewave
24bit Recording XP
Post by davethewave » Wed Nov 14, 2018 2:54 am
How can I record at 24bit using Windows XP? Direct Sound?
Re: 24bit Recording XP
Post by steve » Wed Nov 14, 2018 10:10 am
Audacity no longer supports Windows XP, but you could try using WDM/KS with Audacity 2.0.0, if your XP machine has SSE2 and your sound card drivers support WDM/KS.
Note that the WDM/KS drivers for some old sound cards were buggy and could cause BSOD.
