I recorded over my file
Taverneiro
Post by Taverneiro » Mon Nov 12, 2018 5:51 am
Hello humans , I need help. I recorded a two-hour podcast and, when it came time to edit, I accidentally saved it. Can you guys help me get it back? This is very important for me! thanks in advance. ;)
Re: I recorded over my file
Post by steve » Mon Nov 12, 2018 9:03 am
You "Saved" the Audacity Project? So what is the problem? Did you also close the project and now you can't find the project that you saved? Your question doesn't make sense. :?
Taverneiro
Post by Taverneiro » Mon Nov 12, 2018 2:35 pm
ooo, my distraction, i silenced my project before save. Can I get it back?
Post by steve » Mon Nov 12, 2018 3:27 pm
If you mean "muted" (clicked the track "Mute" button), then you can just click it again to unmute, but I guess you mean that you actually converted the tracks to "silence" (flat line).
If you converted the tracks to silence, or deleted the track before saving, and closed the project after saving, and you have no backups, then it is almost certainly gone forever. If you did not close the project, then you should be able to use "Undo" (Ctrl + Z) to wind back to the point before you silenced it.
Taverneiro
Post by Taverneiro » Mon Nov 12, 2018 3:43 pm
I missed the project then. thank you.
