Trying to meet ACX specifications
Re: Trying to meet ACX specifications
Post by kozikowski » Fri Nov 16, 2018 7:05 pm
Screen Shot 2018-11-16 at 10.44.05.png (40.31 KiB) Viewed 449 times
Alice4raw11162018Patched.wav
(1.69 MiB) Downloaded 20 times
The catch is I had to design a custom filter to get rid of what I'm assuming is computer fan noise. You have a background hum or whirr at 81Hz musical pitch. It gets reduced in the Low Rolloff equalization step, but not enough to pass. 81Hz is not a regular hum sound such as 60Hz in the US and 50Hz in the UK. It's such an odd pitch that it almost has to be computer fan noise as computers don't have to follow the power system like an air conditioner or other room vent fans.
Even in the studio, can you tell if the computer is on just by listening?
You can do the rest of the work just by adding the custom filter before you apply Mastering 4. It shouldn't affect your voice.
Effect > Notch Filter > 81Hz, Q 6.
Screen Shot 2018-11-16 at 10.53.11.png (22.41 KiB) Viewed 449 times
Don't change the computer. If that's what it is, you are now married to that computer's fan noise.
So that's the technical considerations. That leaves theater. This is where I take one step back and you get to decide if you like the voice quality and everything about the sound. I think it's fine as it is, but there are very few voices where somebody can't find some way to change it. We should remember that your mastering process is already 25% longer than regular mastering (four steps instead of three) and you will need to remember to apply all the corrections to each chapter. Anything else you do is going to be in addition to all that.
Trebor
Post by Trebor » Fri Nov 16, 2018 8:35 pm
chuckyocum wrote:
Fri Nov 16, 2018 5:24 pm
... Still doesn't pass ACX noise floor.
ChuckAlice4raw11162018.wav
There's a lot of infrasound in that , which no-one can hear but apparently is measured by the ACX tool.
If you remove those inaudible frequencies with this rumble-filter equalization, it passes ACX noise-floor test ...
100Hz rumble filter.png (23.06 KiB) Viewed 444 times
chuckyocum
Operating System: Windows 7
Post by chuckyocum » Fri Nov 16, 2018 9:00 pm
WOW WOW WOW! Thanks again, Koz.
I'll definitely do the notch filter. But note that the computer is totally outside the whisper room, just leaving a solid-state keyboard inside on the table.
Chuck
chuckyocum
Post by chuckyocum » Fri Nov 16, 2018 9:02 pm
Thanks, Trebor. I'll try the 100Hz rumble filter, also.
Chuck
Post by kozikowski » Fri Nov 16, 2018 9:28 pm
How are you getting ventilation in the room? Mini whisper fans? Can you hear them change if you unplugged them?
Screen Shot 2018-11-16 at 13.16.52.png (125.59 KiB) Viewed 439 times
We had a conference room at work which was soundproofed. I sent a number of sound performances through that room. Yes, it had padded walls, etc, but it also had padded air ducts and I couldn't tell when the air conditioner went on.
If someone unplugged the computer with you in the room, could you hear it wind down? That whir tone behind your voice is coming from somewhere and it has all the signatures of a computer fan. If it walks like a duck.....
There is an insane test you can do with a long microphone cable. Look for the hum like that guy at the beach looking for Rolodex Watches in the sand with a metal detector.
Screen Shot 2018-11-16 at 13.24.11.png (113.97 KiB) Viewed 439 times
It's almost certainly a directional microphone so you aim it all over while wearing headphones and set Audacity for live monitor. The whir will get louder as you approach the noisemaker. That's how I found my music bass cabinet didn't go off when I turned it off and it sat there making a low volume hum that drove me nuts for a year.
Post by kozikowski » Fri Nov 16, 2018 9:40 pm
You should be careful with that. Audiobook Mastering 4 has a 100Hz rumble filter built in and you shouldn't apply both.
viewtopic.php?f=64&t=96103
chuckyocum
Post by chuckyocum » Mon Nov 26, 2018 9:07 pm
Hi koz,
Tried notch filter on my computer with Audacity 2.3.0 (see attached waveform). Failed ACX noise floor -55.5dB.
Fully mastered and Eq only pass (see attached) (-64.0 and 61.3, respectively).
Please listen to the audio. I'd love to know whether sound/theater quality of Eq only and fully mastered are OK. Also, could you suggest why my notch filter didn't pass? Also should I just master using Eq to minimize actions that might fail ACX sound/theater quality?
Thanks very much!
Chuck
Alice4raw11162018 mastered.wav
(1.69 MiB) Downloaded 21 times
Alice4raw11162018 eq only.wav
(1.69 MiB) Downloaded 15 times
Alice4raw11162018 notch.wav
(1.69 MiB) Downloaded 18 times
DVDdoug
Forum Crew
Post by DVDdoug » Mon Nov 26, 2018 11:14 pm
The notch filter should be used in addition to the other processing. I only notches-out 82Hz noise.
The default low-frequency roll-off is just to reduce low-frequency noise. And, since there is no deep bass in voice recordings the low-frequency roll-off doesn't affect the (good) sound.
Additional EQ can be used (sparingly) to as a corrective-effect to correct for microphone frequency response variations (i.e. if you microphone sounds "dull", etc.) or as an artistic or special-effect to slightly-change the character of your voice.
Trebor
Post by Trebor » Tue Nov 27, 2018 2:26 am
.. I'd love to know whether sound/theater quality of Eq only and fully mastered are OK ...
That does have a lot of mouth clicks. They can be reduced using a free plugin for Audacity called Paul-L's de-clicker ...
this does not address all clicking problems: it only reduces the loudest high-pitched ones.
mouth-click reduction settings used.png (21.02 KiB) Viewed 345 times
