Recording streams
sombunya
Recording streams
Post by sombunya » Sun Oct 21, 2018 3:36 am
Windows 10 laptop.
I've been using Audacity for years to digitize my vinyl albums and see no reason to look at any other program. I love it.
I recently installed 2.3.0 on my laptop and I'm experiencing some issues recording streaming audio.
I can't get the levels high enough, they seem attenuated, and the playback sounds poor compared to the source. Sort of a "canned" sound.
I've gone through most of the settings, I believe, and can't seem to find the correct ones. Any help is appreciated.
sombunya
Re: Recording streams
Post by sombunya » Sun Oct 21, 2018 4:40 am
I've gotten to where it sounds good, but still no control over record volume. I have to set it at the source, a bit inconvenient.
Is there a fix so I can set it in the Audacity window?
Thank you.
sombunya
Post by sombunya » Sun Oct 21, 2018 6:40 am
If I can add one more thing; I'm getting pretty good results recording streams from the net. However, a while back I recorded some tracks from an LP and did a true A/B listening test. The recording was absolutely identical to the program to my ears. I could not tell the difference.
When I record a stream the quality is good but the source sounds just a little cleaner with just a bit more punch. I've tried many different settings and I can still diferentiate the source from the recording.
Again, any help is greatly appreciated.
And to any one else reading this, donate a few bucks. I've totally gotten my money's worth.
Post by steve » Sun Oct 21, 2018 8:50 pm
That's normal. You are recording the signal that is being sent to the audio playback, so only the playback volume affects the recorded signal level.
The "fix" (really just a "workaround") is to plug headphones / speakers into the audio device / soundcard that you are using, and use the volume control on the headphones / speakers.
If you are using "WASAPI loopback" as the recording source, then it "should" sound identical. If you are using "Stereo Mix" or "What U Hear", then the sound quality may be compromised by the quality of the sound card / audio device.
