All DJ programs I've tried only find the data folders.They don't even see the wave files that I've exported.Is there any
DJ software that will see audacity files?Or at least the wave files from audacity projects.
DJ Mixing Software
davethewave
Re: DJ Mixing Software
AUP project files are ONLY for use by Audacity.Is there any DJ software that will see audacity files?
Any DJ software should be able to play WAV, AAC, or MP3, and maybe FLAC. What features do you need? Windows Media Player, iTunes, or "good-old" Winamp can play a playlist with optional cross-fading. There is a 3rd-party smart crossfader for Winamp that does can do a "DJ style crossfade" (an overlap without any additional fade) but I never could get it to work without glitching. Sam DJ ($100) has a similar smart crossfader but I haven't tried it.Or at least the wave files from audacity projects.
