I was editing a recording yesterday (and saving along the way), when a storm hit my area and knock out the power to my home. When I was able to restart my editing, my file was gone. It showed up in “my document”, both the file and the audio icon, however when I clicked on the audio icon, I received an error message that stated: “C:\Users\Doris\Documents\ABR.10.22.18 DLee working.aup” is an Audacity Project file. Use the file > Open’ command to open Audacity Projects.
That is exactly what I am doing, so I don’t understand why I keep getting that error. This was not a new file. I had completed the recording on 10/14/18. I completely closed it after completing it. I then opened it yesterday to edit it and everything was fine until the storm hit. Can you help me find this file?
Thank you for replying so quickly Steve. You said ABR 10.22.18 DLee working.aup (59.1 KB)
what I am thinking because I’m not able to retrieve it. I was able to drag the actual audio file in. Please let me know what you find out.
When the storm breaks out, quickly make a “Lossless Copy of Project” to an external hard drive, then disconnect the hard drive and put it in the bombproof, waterproof, fireproof safe in your cellar
These copies are big, because by default the audio is 32-bit float, the same as the project itself, but unlike a normal project, the tracks are rendered to 32-bit WAV files, so you have a perfect snapshot of the project that is a lot more robust than a standard project (which has thousands of little data fragments).
