Folder creation problem
Merowinger
Re: Folder creation problem
Yeah, sounds very similar.
waxcylinder
I added a link to this Forum thread to the Bugzilla entry: https://bugzilla.audacityteam.org/show_ ... id=1899#c2
Tested on Windows 10 and I can reproduce the problem.
What's happening is that when the Audacity "File Import", or "Macro > Files" dialog is opened, if the last used Import folder does not exist, Audacity is creating it. This should not happen (other applications don't appear to do this on Windows).
I've logged to bug here: https://bugzilla.audacityteam.org/show_bug.cgi?id=2007
Merowinger
Thank you very much!
Merowinger
Any news about this bug? Will it be fixed in the next version?
You can view the current status at any time here: https://bugzilla.audacityteam.org/show_bug.cgi?id=2007Merowinger wrote: ↑Wed Oct 24, 2018 8:30 amAny news about this bug? Will it be fixed in the next version?
Merowinger
Thank you.
Merowinger
Not fixed in the new version.
