macro question
macro question
I just updated to the new version(2.3.0) and saw that the chains function has been expanded and rename macros. I dont have a lot of experience with macros and programming so I was wondering if it is possible to have audacity start a new track evetime it stops when it is recording with sound activated recording turned on?
Re: macro question
No, it can't do that.
What is it you are trying to do, and why do you need to use sound activated recording?
