2.3.0 Debug Error
DarkSwordsman
2.3.0 Debug Error
Post by DarkSwordsman » Tue Oct 02, 2018 8:32 pm
Here is the error:
After pressing Continue 5 times I can use the application, but this is not usable for our University computers. I'll try reinstalling, otherwise, I'll go back to 2.2.2 until it's fixed or a solution is found.
How to reproduce:
1. Install 2.3.0 with 2.2.2 already installed
2. Once finished, start the application
Log File:
Code: Select all
16:30:14: Audacity 2.3.0
16:30:14: Trying to load FFmpeg libraries...
16:30:14: mLibAVFormatPath ('C:\Program Files (x86)\Lame For Audacity\avformat-55.dll') is not empty. Loading from it.
16:30:14: Looking up PATH environment variable...
16:30:14: PATH = 'C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\UCRT\;C:\Program Files\Intel\UCRT\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\PharosSystems\Core;C:\Users\administrator\AppData\Local\Microsoft\WindowsApps;'
16:30:14: Checking that 'C:\Program Files (x86)\Lame For Audacity' is in PATH...
16:30:14: Warning: FFmpeg directory 'C:\Program Files (x86)\Lame For Audacity' is not in PATH.
16:30:14: Temporarily prepending ';C:\Program Files (x86)\Lame For Audacity' to PATH...
16:30:14: Checking for monolithic avformat from 'C:\Program Files (x86)\Lame For Audacity\avformat-55.dll'.
16:30:14: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
16:30:14: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
16:30:14: avformat not monolithic
16:30:14: Loading avutil from 'avutil-52.dll'.
16:30:14: Error: Failed to load shared library 'avutil-52.dll' (error 126: The specified module could not be found.)
16:30:14: Loading avcodec from 'avcodec-55.dll'.
16:30:14: Error: Failed to load shared library 'avcodec-55.dll' (error 126: The specified module could not be found.)
16:30:14: Loading avformat from 'C:\Program Files (x86)\Lame For Audacity\avformat-55.dll'.
16:30:14: Returning PATH to previous setting...
16:30:15: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 0: The operation completed successfully.)
16:30:15: Actual avutil path
16:30:16: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 0: The operation completed successfully.)
16:30:16: Actual avcodec path
16:30:16: Error: Couldn't find symbol 'avformat_version' in a dynamic library (error 127: The specified procedure could not be found.)
16:30:16: Actual avformat path
16:30:16: Importing symbols...
16:30:16: Error: Failed to load symbol av_register_all
16:30:16: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
16:30:16: Looking up PATH environment variable...
16:30:16: PATH = 'C:\Program Files (x86)\Lame For Audacity;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\UCRT\;C:\Program Files\Intel\UCRT\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\PharosSystems\Core;C:\Users\administrator\AppData\Local\Microsoft\WindowsApps'
16:30:16: Checking that '' is in PATH...
16:30:16: FFmpeg directory is in PATH.
16:30:16: Checking for monolithic avformat from 'avformat-55.dll'.
16:30:16: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
16:30:16: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
16:30:16: avformat not monolithic
16:30:16: Loading avutil from 'avutil-52.dll'.
16:30:16: Error: Failed to load shared library 'avutil-52.dll' (error 126: The specified module could not be found.)
16:30:16: Loading avcodec from 'avcodec-55.dll'.
16:30:16: Error: Failed to load shared library 'avcodec-55.dll' (error 126: The specified module could not be found.)
16:30:16: Loading avformat from 'avformat-55.dll'.
16:30:16: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 0: The operation completed successfully.)
16:30:16: Actual avutil path
16:30:16: Error: Failed to find compatible FFmpeg libraries.
Reason: Insert image into post for direct viewing
Re: 2.3.0 Debug Error
Post by steve » Sat Oct 06, 2018 5:29 pm
Did you build Audacity yourself or did you install the official release version from: https://www.audacityteam.org/download/windows/
waxcylinder
Post by waxcylinder » Sun Oct 07, 2018 9:31 am
I cannot reproduce this error following the Steps to reproduce:
How to reproduce:
Rampak
Post by Rampak » Tue Oct 09, 2018 11:55 am
I'm getting the same problem. Tried uninstalling V2.2.2 before installing V2.3.0 without success.
Installed using the Windows installer from the Audacity site.
Reverted to V2.2.2
Post by steve » Tue Oct 09, 2018 3:07 pm
Are you also installing on a network?
Do you have WxWidgets installed?
Rampak
Post by Rampak » Thu Oct 11, 2018 8:25 am
No don't have WxWidgets.
I'm installing directly onto a computer, although the computer is connected to a network.
As stated V2.2.2 installs fine.
Post by steve » Thu Oct 11, 2018 10:20 am
Is the text in the "wxWidgets Debug Alert" exactly the same as reported by DarkSwordsman ?
(it would be helpful if you could copy and paste the error message into your reply - it's impossible to search the code without the errors as text.)
Rampak
Post by Rampak » Fri Oct 12, 2018 1:16 pm
Attached is a screenshot of the message I get when I try to run V2.3.0
Audacity error.JPG (53.07 KiB) Viewed 327 times
Post by steve » Fri Oct 12, 2018 1:30 pm
Assuming that you can get Audacity 2.3.0 to run by pressing "Continue" a few times, please post screenshots of:
"Help menu > About Audacity" (first tab)
then select the "Build Information" tab, scroll down to the bottom, and take a screenshot of that also.
DarkSwordsman
Post by DarkSwordsman » Mon Oct 15, 2018 4:42 pm
Sorry for the delay, haven't been at work for a few days.
So the issue I ran into was on a Optiplex 3050 PC. I tried 2.3.0 on a Precision 3620 that we are about to roll out and it doesn't have any issues, works perfectly as expected.
I downloaded it from that site, and on Fosshub I selected "Installer".
Seeing that we released that 3050 PC and it works fine with 2.2.2, I won't really be touching it for a few days. We have to roll out these 3620s ASAP.
^^ I'll do this when I get around to the PC.
Thanks for the help so far everyone.
