So I downloaded Gsnap and autotalent, put them in the plugin folder, made sure they were 32-bit, and theyre still not appearing in the add/browse plug ins. Nor are they appearing in the effects. Please help Im quite irritated.
Recently the Audacity plugins folder moved from “Program Files” to this hidden folder …
C:\Users\<YourNameHere>\AppData\Roaming\audacity\Plug-Ins
If you put plugins in the old Audacity plugins folder, (in “C:\Program Files\Audacity\Plug-Ins”), they won’t be visible.
Thanks so much.
