Hi, I know u can isolate vocals from a song but can you take that removed vocal track and use it to create a new track with just my noise reduction removed vocals? Thanks for the time
What???
Do you want to remove the music and keep the vocals?
Remove the vocals and keep the instruments?
Mix the results with a new voice or instrument recording?
I can’t follow the message either. Effect > Vocal Reduction and Isolation can give you (as much as possible) either the music or the vocal by itself. Is that what you want?
