where is the code of Highlighting of tracks on mouse dragging
arizansari
Post by arizansari » Sat Aug 25, 2018 4:18 am
I want to use audacity code in my Project
So I want to know the location of the code of HIGHLIGHTING OF THE TRACK when user select the region on mouse drag. Where is the drawing taking place that HIGHLIGHT the selected region.
Re: where is the code of Highlighting of tracks on mouse dragging
Post by steve » Sat Aug 25, 2018 11:22 am
It's mostly in TrackArtist.cpp, but the code is very specific to Audacity so I don't expect it will be much help for other applications, other than perhaps providing some ideas.
arizansari
Post by arizansari » Sun Aug 26, 2018 2:21 pm
I want to have multiple selection and the selection rectangle should have dotted boundaries and each rectangle must be of different colors.
