Deleting parts of A Project in the aud folder is easy but how do you(safely) delete the files from the Data folder? Or is this
not possible?
davethewave
Re: Deleting parts of A Project
The only safe way to modify Audacity projects is with Audacity. Manually editing the AUP or _data are not recommended.
See: https://manual.audacityteam.org/man/aud ... jects.html
