Merge multiple mp3
djdan_23
Operating System: Windows 7
Merge multiple mp3
Post by djdan_23 » Thu Aug 16, 2018 11:58 am
I'm using this nice software since many years now. And now I would like to use it
to merge multiple mp3 together to have only one track.
What would be the easiest and best way to do it.
Thanks at advance.
Audacity 2.2.2
Windows 7
waxcylinder
Re: Merge multiple mp3
Post by waxcylinder » Thu Aug 16, 2018 2:07 pm
1) Import all the MP3 files into Audacity
2) they will all be on separate tracks
3) use Tracks > Align Tracks > Align End to End
4) they will all still be on separate tracks but lined up one after the other
5) use File > Exprt > Export as MO3
6) result -> a single MP3 file where all the imported MP3s play one after the other.
djdan_23
Post by djdan_23 » Thu Aug 16, 2018 8:12 pm
Many thanks it works perfectly.
One observation: we must do "SELECT ALL" between #2 and #3 of your explanation. ;)
waxcylinder
Post by waxcylinder » Fri Aug 17, 2018 3:11 pm
Oh yes, sorry that was remiss of me :oops:
But glad you got it working for you.
