How to set up a chain that uses COPY and PASTE with several tracks
MrKristoffVA
Post by MrKristoffVA » Thu Aug 16, 2018 5:05 am
I'm currently creating a robot voice in Audacity and the process involves copy/pasting the main voice file several times and applying different pitches and effects to each track individually and then mixing them together. I have nearly 50 individual voice lines on which I need to use this process.
The chain creation tool allows me to apply specific effects to a single track, but does not seem to have a way to set up a process as specific as this.
Am I missing something or is this not possible?
The only solution I've been able to come up with is to lay every voice file I have back to back and then process all of them as one voice track, then separate and save them as unique files.
Contact:
Re: How to set up a chain that uses COPY and PASTE with several tracks
Post by steve » Thu Aug 16, 2018 10:01 am
It is not currently possible.
MrKristoffVA
Post by MrKristoffVA » Thu Aug 16, 2018 12:39 pm
Thanks, that's what I figured.
xovolarjem
Post by xovolarjem » Sat Aug 18, 2018 4:43 pm
Not practically possible as far as my knowledge say otherwise I would have loved to use the features too.
With Regards,
Xovo larjem
