Cursor alignment
paulsintes
- Operating System: Windows XP
Cursor alignment
Is there a way to get a vertical cursor full screen (top to bottom) to enable me to accurately move and align start points of tracks?
Re: Cursor alignment
You can create a label at the point where you want to align audio clips. (See: https://manual.audacityteam.org/man/bou ... uides.html)
