Pitch control not working. Munchkin effect
dworkenlaw1
Operating System: Windows 7
Post by dworkenlaw1 » Sun Aug 05, 2018 5:49 am
Can anyone help this first day user? I opened the pitch control and edited the song from Db to G. When I previewed, the song played in G, but it was munchkin. How do I raise pitch but maintain the vocal? Thank you. Patrick
Re: Pitch control not working. Munchkin effect
Post by steve » Mon Aug 06, 2018 9:10 pm
Are you referring to the "Transcription Toolbar" https://manual.audacityteam.org/man/tra ... olbar.html
or to the "Change Pitch" effect: https://manual.audacityteam.org/man/change_pitch.html
or something else?
dworkenlaw1
Post by dworkenlaw1 » Sat Sep 22, 2018 2:43 am
SORRY FOR THE DELAY. I USED THE CHANGE PITCH BUTTON.
Post by steve » Sun Sep 23, 2018 7:58 pm
What is the "CHANGE PITCH BUTTON"?
