Could not find audio devices-port audio error
Thierry410
Post by Thierry410 » Thu Jul 26, 2018 7:14 am
I get this message when launching, whild my sound cards work perfectly with all othe apps...
TIA for tips !
Re: Could not find audio devices-port audio error
Post by steve » Thu Jul 26, 2018 11:12 am
Audacity may not find your audio device if another application has grabbed exclusive control of the device (Skype is notorious for grabbing exclusive control of the recording device).
Try rebooting your computer, then check that there are no audio applications that have started up on boot (such as Skype), then try launching Audacity. Does it start now without the error?
ve4jhj
Post by ve4jhj » Thu Jul 26, 2018 10:43 pm
That might be related to a recent change Microsoft made to the privacy settings. See here: viewtopic.php?f=46&t=100117
