Help file proof reading
edwinn
Operating System: Windows 7
Post by edwinn » Tue Jul 24, 2018 1:43 pm
Is there a place to report issues with the Help file? Think I found a need for minor correction.
-Ed
Re: Help file proof reading
Post by steve » Tue Jul 24, 2018 1:48 pm
Sure, you can post here. Please give a link to the relevant document and quote exactly the bit that you think needs correcting.
edwinn
Post by edwinn » Tue Jul 24, 2018 2:05 pm
See word circled in Red.. believe if should read `upper´.
-Ed
Post by steve » Tue Jul 24, 2018 2:17 pm
Thanks. I've corrected it in the alpha manual so it will be correct in the next release. (https://alphamanual.audacityteam.org/ma ... -2:_Repeat)
waxcylinder
Post by waxcylinder » Tue Jul 24, 2018 5:16 pm
Good catch - thanks edwinn
Peter
