Project rate.
Re: Project rate.
Post by steve » Tue Jul 24, 2018 6:50 pm
юра00 wrote:
Tue Jul 24, 2018 6:26 pm
Is there a key that changes the project rate?! More precisely, allows to switch its value in the lower left corner. How!?
That one is a bit tricky unless you have a screen reader to help identify where you are in the interface.
"Ctrl + F6" to move focus to the toolbars, then "Tab" through to the Project Rate box, then type in the required project rate.
Yes it's easier to do that with a mouse, which for a sighted person is no great hardship, especially as you will only need to do it once in the lifetime of the project.
юра00
Re: Project rate.
Post by юра00 » Tue Jul 24, 2018 7:05 pm
Thank you! Of course, in practice it is of little use, but, in principle, it is possible.
