Prevent Loss of History
christianw
Post by christianw » Sat Jul 21, 2018 11:37 pm
For me it's a workflow issue:
Is there a way to save a project without losing the history?
I would like to be able to undo changes after saving the edited file.
Re: Prevent Loss of History
Post by steve » Sun Jul 22, 2018 10:23 am
Currently, the only way is to make frequent backups using "Save Project As...", each uniquely named, for example:
My-project001.aup
My-project002.aup
My-project003.aup
christianw
Post by christianw » Sun Jul 22, 2018 3:26 pm
Thanks. I will incorporate that.
CW, 2.2.2
