Poor audio quality recording computer playback
teedus2002
Post by teedus2002 » Sat Jul 21, 2018 6:55 pm
I used to have no problem using either Stereo Mix or the Windows WASAPI method, however, now when I try to record computer audio the quality is just very poor. I'm using the same computer I used before I had any problems and I haven't done any changes to my sound card or anything. This is really getting annoying...
Re: Poor audio quality recording computer playback
Post by kozikowski » Sat Jul 21, 2018 10:02 pm
Can you hear the dogs barking next door? One of the Stereo Mix services records The Whole World including the built-in microphone. Could you be listening to you shuffle your chair while you record?
