audacity-win-2.2.2.exe download is only 253 KB
petrula
Post by petrula » Fri Jul 20, 2018 9:29 pm
Windows 10 Pro 64-bit
Go to
https://www.audacityteam.org/download/windows/
Notice the following:
Audacity 2.2.2 installer (19.31 MB, includes help files)
I left-click the text link to start the download.
The download is named "audacity-win-2.2.2.exe".
It is only 253 KB.
Something is really wrong.
Did someone hack the web site?
Thank you for the feedback.
Re: audacity-win-2.2.2.exe download is only 253 KB
Post by steve » Sat Jul 21, 2018 1:52 am
I've just checked the file and it is fine.
The SHA-256 is ca19471e10660765dec12c980ebd3eeb9b82826ea4f25bc490936f312b14caff
and the file size is 20248056 bytes.
Try clearing your web browser cache and download it again.
petrula
Post by petrula » Sat Jul 21, 2018 4:18 am
Thank you for your help.
I found the problem.
Go to
Above Audacity 2.2.2 installer (19.31 MB, includes help files), it says
"Left-click the text link to start the download. Right-click and “Save as…” will not work."
Ugh, I messed up and did not follow instructions correctly since I use a left handed mouse so forgot everything is reversed.
What happens is that "Save as..." downloads a file named "audacity-win-2.2.2.exe" which is only 253 KB size. Unclear why this file is downloaded.
VirusTotal says that it has a JavaScript (JS) virus of some sort.
https://www.virustotal.com/#/file/843e1 ... /detection
Bkav JS.eIframeDwNMe.1D87
I cannot find any information about JS.eIframeDwNMe.1D87.
When I "Left-click (right-click with left handed mouse) the text link to start the download.", it downloads the correct sized file with correct SHA256.
ve4jhj
Post by ve4jhj » Sat Jul 21, 2018 4:42 am
The single detection on VirusTotal is what's known as a "False Positive". It's nothing to be concerned about.
Post by steve » Sat Jul 21, 2018 8:34 am
Due to the "leech protection" on the FossHub site, if you right click, the file that downloads is the web page rather than the file.
