Hi I’m new to Audacity (2.2.2) and would appreciate any advice on a microphone type to get started with. Any make or model suggestions would be appreciated. I’m running Win XP SP3 on a fairly fast quad core machine. Many thanks
What are you wanting to record, and what is your budget?
Get started doing what?
Can you tell if your machine is on just by listening? I’m guessing yes and that will limit what you can achieve without knowing anything else about you.
