"Normalize" to 0 by hot key.
юра00
Post by юра00 » Mon Jul 16, 2018 4:30 pm
Is there a key, that would perform the action effect "Normalize" to 0 (maximum)?
DVDdoug
Forum Crew
Re: "Normalize" to 0 by hot key.
Post by DVDdoug » Mon Jul 16, 2018 5:23 pm
Not be default.
You can set-up a hotkey via Edit -> Preferences -> Keyboard but I think that will only open the effect.
You can probably do it with Batch Processing.
You could also write a script for SoX.
Post by steve » Mon Jul 16, 2018 6:06 pm
Yes you can do that, and as you say, it does just open the effect.
The effect will open with the settings that were last used, so if those settings are correct, pressing the Enter key will apply the effect.
It would be possible to create a Nyquist plug-in to normalize to 0 dB, and then create a shortcut to the Nyquist plug-in, but the two key press version above is a much simpler option.
юра00
Post by юра00 » Mon Jul 16, 2018 8:42 pm
Thank you! Like, I've understood. I installed the N key. However, now I can't use it for its intended purpose, but it is not needed, only numbers need to be entered.
юра00
Post by юра00 » Tue Jul 17, 2018 5:15 am
For the help about the Batch-chains thank you very much!
