Hi guys,
I’ve got a big issue with my audacity.
Last year I started recording with it and a focusrite 2i4 interface. At first I installed Ableton lite wich came with the focusrite interface, but I looked too complicated so I went for Audacity instead.
As soon as I started recording I had a loud distortion on the track (see attached file), no mater the mic or the input I would use. The weird thing is, if I would open Ableton and close it, it would work perfectly. So I used this method for a year because I had to record an EP and I didn’t want to deal with it.
But I dont need Ablton and it’s taking a lot of room. So I removed it. Boom ! the problem is back !
I thaught that maybe it was a hardware problem so I send it back to thoman, they check it and said it was perfectly fine. Then I checked with focusrite, they had me do a bunch of test and told me it was a software problem.
So I went back to my old trick with Ableton but it’s really annoying. I have to start Audacity, then shut it down, then start Ableton etc… I’d like my Audacity to work normaly.
So I would be great, really great if someone could help me
