Are the two incompatible?
Hacutie297
Post by Hacutie297 » Sun Jul 01, 2018 6:11 am
Win 7 Home Premium Service Pack 1
Audacity 2.0.4 installed by .exe
Been puttering around with Audacity as a hobby, creating ringtones/soundbites from old pop tunes - having fun and learning quite a bit. But a couple of times, it has seemed like if the tempo effect was applied to a track in which the envelope tool had been used, the enveloping was reversed before the tempo was changed. Are the two incompatible? Or does tempo have to precede envelope? There was no warning the reversal would happen.
Thanks in advance...
jh90s
Re: Are the two incompatible?
Post by jh90s » Sun Jul 01, 2018 8:04 am
Not sure about the issue, but a quick heads-up: 2.0.4 is quite old now. I suggest you grab 2.2.0 (it may even have that issue fixed!)
Post by steve » Sun Jul 01, 2018 9:08 am
jh90s wrote:I suggest you grab 2.2.0
The current version is Audacity 2.2.2.
jh90s
Post by jh90s » Sun Jul 01, 2018 9:41 am
That's what I get for typing a response when tired... oops. haha
