Best Choice of "Audio Host"
dbrunnen
Post by dbrunnen » Thu Jun 28, 2018 4:05 pm
Is there a preferred "Audio Host" mode when recording stereo audio using a USB-connected Focusrite or Behringer analog-to-digital converter? For this question, assume that the appropriate driver is installed for each converter and that it is selected as the Recording Device.
Dennis, aka "dbrunnen"
P.S. Windows 7 or 10, Audacity 2.2.2
DVDdoug
Forum Crew
Re: Best Choice of "Audio Host"
Post by DVDdoug » Thu Jun 28, 2018 6:18 pm
WASAPI is the newest and MME is the oldest. If WASAPI works I'd use it. Here is some information I ran-across awhile back.
