Need help?
anhnn1234
Need help?
Post by anhnn1234 » Mon Jun 25, 2018 4:04 am
Hi all! Trying to find more efficient ways to edit "ums" and tongue-clicks etc. Finding the way Quick-Play scrolls (moving all the way to the right of the screen, and then rebooting a new window of track content) to be suboptimal.
Is there a preference where I can tell the Quick-Play green arrow to stay centered on the screen and instead have the various tracks scroll right to left across the screen? This would allow a fixed and broader window of content to edit.
Thanks!
waxcylinder
Re: Need help?
Post by waxcylinder » Mon Jun 25, 2018 9:20 am
Trebor
Re: Need help?
Post by Trebor » Mon Jun 25, 2018 9:44 am
anhnn1234 wrote:...Trying to find more efficient ways to edit ... tongue-clicks ...
This De-Clicker plugin can find & remove those faster than you can ... viewtopic.php?p=245549#p245549
