Way to center quick-play on screen so the tracks scroll?
AirstreamPodder
Operating System: Windows 7
Post by AirstreamPodder » Sun Jun 24, 2018 8:26 pm
Hi all! Trying to find more efficient ways to edit "ums" and tongue-clicks etc. Finding the way Quick-Play scrolls (moving all the way to the right of the screen, and then rebooting a new window of track content) to be suboptimal.
Is there a preference where I can tell the Quick-Play green arrow to stay centered on the screen and instead have the various tracks scroll right to left across the screen? This would allow a fixed and broader window of content to edit.
Thanks!
waxcylinder
Re: Way to center quick-play on screen so the tracks scroll?
Post by waxcylinder » Sun Jun 24, 2018 9:45 pm
Click on the green upside down triangle at the left of the Timeline - that icon will turn into a green drawing pin, indicating fixed, centred, playhead.
See: https://manual.audacityteam.org/man/tim ... tml#pinned
AirstreamPodder
Post by AirstreamPodder » Mon Jun 25, 2018 1:00 am
Woohoo!
Many thanks WC!!!
Appreciate it immensely!
M
