Audacity alpha 2.3.0.
юра00
Post by юра00 » Sat Jun 23, 2018 6:51 am
Dear specialists! I've downloaded and installed the alpha version of Audacity 2.3.0. It works very slowly. Please correct! The system language and program language is English.
waxcylinder
Re: Audacity alpha 2.3.0.
Post by waxcylinder » Sat Jun 23, 2018 11:12 am
Are you using multiple tracks?
If so we are aware of this issue and it is already logged as a P1 top priority bug: https://bugzilla.audacityteam.org/show_bug.cgi?id=1886
The P1 rating means that it must be fixed before release?
Thanks for the report though.
юра00
Post by юра00 » Sat Jun 23, 2018 12:04 pm
Nothing is multiple. The most common single track, true, is a mono track. And the speed, in comparison with the release version, fell sharply.
