When I click on “Add / Remove Plug-ins” the program crashes and opens the Debug Report Windows.
Help please.
I cannot reproduce this with 2.2.2 or 2.3.0 alpha on my W10 laptop
Can you try resetting your Audacity settings by deleting the complete contents of your settings folder and the re-try the “Add / Remove Plug-ins”
See this section of the Audacity Manual: https://manual.audacityteam.org/man/installing_and_updating_audacity_on_windows.html#purge
This is the Windows section of the forum, but your profile says Linux. Which are you using?
