Yamaha Keyboard Connection Issue
JayceBruh
Post by JayceBruh » Sat Jun 16, 2018 5:56 am
Window 10, Version 2.1.0. I'm having an issue with connecting my Yamaha and it wont record any audio it state on my Sound settings that it is Currently Unavailable.
ve4jhj
Re: Yamaha Keyboard Connection Issue
Post by ve4jhj » Sat Jun 16, 2018 2:54 pm
This may be related to a change Microsoft made to Windows' Privacy settings. Depending on how your device appears to Windows, this topic may help: viewtopic.php?f=46&t=100117
DVDdoug
Forum Crew
Post by DVDdoug » Sat Jun 16, 2018 6:07 pm
What Yamaha? How is it connected? I assume it's a keyboard with a USB connection?
Some keyboards are USB MIDI only (no USB audio) and Audacity is not a MIDI application.
Post by kozikowski » Sun Jun 17, 2018 4:58 pm
I use the headphone connection and split it between a large sound system and a connection that I record. My Yamaha keyboard does not send sound down the USB connection, It's MIDI-only,
