separating songs from tape
mdrewsr
Operating System: Windows 7
Post by mdrewsr » Sun Jun 03, 2018 2:28 pm
I am new to this whole thing. I just purchased a tape player that will allow me to convert all my tapes to MP3.
When i record the entire tape. I want to separate each song and identify them individually so that I can either
save or delete each song. Right now it just records the tape as a single unit. I would appreciate any help,
suggestions or education that i can get. Thanks
Contact:
Re: separating songs from tape
Post by steve » Sun Jun 03, 2018 3:15 pm
There's a series of tutorials here which should cover everything you need: https://manual.audacityteam.org/man/tut ... to_cd.html
Trebor
Post by Trebor » Sun Jun 03, 2018 3:18 pm
mdrewsr wrote:... I want to separate each song and identify them individually ...
Label each song, then Export multiple
