so i am using a audiobox usb presonus with a m7 presonus microphone and the microphone option is not popping up for me to select it but the speaker option from the headphone is popping up and playing through the headphones connected too the audiobox but i cant get the microphone to show. I tried rescanning audio devices nothing. i just switched over to a windows computer it used to work fine on mac. please help
Audacity isn’t going to see the “microphone”, but it should see the USB device and you should be able to select it as your recording device.
Can you actually play a file from Audacity (or Windows Media Player, etc.) and hear it through the AudioBox? Or are you hearing the sound from mic in your headphones, which may not be going-through the computer?
