Yet Another MP4 import screechy sound issue
Re: Yet Another MP4 import screechy sound issue
Post by kozikowski » Wed May 30, 2018 12:19 pm
I don't do anything in MP4. We'll need to wait for a different forum elf.
Contact:
Post by steve » Wed May 30, 2018 12:43 pm
GreyCoder wrote:5) If someone could point me to a known working MP4 file I'd be happy to test against it
Here's a 10 second test file:
test.m4a
(242.6 KiB) Downloaded 124 times
This is what MediaInfo says about it:
Code: Select all
Format                                   : MPEG-4
Format profile                           : Apple audio with iTunes info
Codec ID                                 : M4A  (isom/iso2)
File size                                : 243 KiB
Duration                                 : 10s 37ms
Overall bit rate mode                    : Constant
Overall bit rate                         : 198 Kbps
Encoded date                             : UTC 1904-01-01 00:00:00
Tagged date                              : UTC 1904-01-01 00:00:00
Writing application                      : Lavf56.40.101
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 10s 37ms
Duration_LastFrame                       : -18ms
Bit rate mode                            : Constant
Bit rate                                 : 196 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 44.1 KHz
Frame rate                               : 43.066 fps (1024 spf)
Compression mode                         : Lossy
Stream size                              : 240 KiB (99%)
Default                                  : Yes
Alternate group                          : 1
GreyCoder
Post by GreyCoder » Fri Jun 01, 2018 7:40 am
ok I did some more experimenting. I downloaded some more YouTube videos and none of them worked.
I took some videos with my YI 4K (not plus) and they also didn't work.
All of them were too big to upload here. So I tried the following:
1) Used Audacity to generate a know tone (500hz). Took a video of it with my YI 4K (non plus). That didn't work with Audacity either. So I tried using FFmpeg with various settings to see if I could compress it down to a small enough file size so I could upload it here. To my surprise I came up with two files, one worked, one doesn't. I'm uploading them here.
For clarity: both of these MP4 files were compressed by FFmpeg from an original YI 4K video of Audacity playing a generated tone. 500hz
ffmpeg -i ydxj0020.mp4 -vf scale=-1:1080 -crf 21 -preset slow -c:a copy smaller-21.mp4 // doesn't work
ffmpeg -i ydxj0020.mp4 -vf scale=-1:1080 -crf 22 -preset slow -c:a copy smaller7-22.mp4 // Works
MediaPro gives the following information from the original YI 4K MP4 file:
Code: Select all
General
Complete name                            : G:\zz zz zz YI 4K- test\Test Batch 3\YDXJ0020.MP4
Format                                   : MPEG-4
Format profile                           : JVT
Codec ID                                 : avc1 (avc1/isom)
File size                                : 3.41 MiB
Duration                                 : 792 ms
Overall bit rate mode                    : Variable
Overall bit rate                         : 36.1 Mb/s
Encoded date                             : UTC 2014-01-01 19:21:42
Tagged date                              : UTC 2014-01-01 19:21:42
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : [email protected]
Format settings                          : CABAC / 1 Ref Frames
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 1 frame
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 792 ms
Bit rate mode                            : Variable
Bit rate                                 : 36.0 Mb/s
Maximum bit rate                         : 24.0 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Standard                                 : Component
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.723
Stream size                              : 3.40 MiB (100%)
Title                                    : XiaoYi AVC
Language                                 : English
Color range                              : Full
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : AAC
Format profile                           : LC
Codec ID                                 : mp4a-40-2
Duration                                 : 789 ms
Bit rate                                 : 132 kb/s
Nominal bit rate                         : 48.0 kb/s
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Stream size                              : 12.9 KiB (0%)
Title                                    : XiaoYi AAC
Language                                 : English
smaller7-21.mp4
Doesn't work
ffmpeg -i ydxj0020.mp4 -vf scale=-1:1080 -crf 21 -preset slow -c:a copy smaller7-21.mp4
(1.81 MiB) Downloaded 112 times
smaller7-22.mp4
Works
(1.52 MiB) Downloaded 112 times
Reason: code tags added to improve readability
GreyCoder
Post by GreyCoder » Fri Jun 01, 2018 7:43 am
Thanks!
I downloaded the test file and it works ok in Audacity.
It plays ok in VLC but didn't have any video. I assume that's as intended.
GreyCoder
Post by GreyCoder » Fri Jun 01, 2018 7:47 am
I should have made this more clear in my last post.
Looking at the different FFmpeg command line parameters it appears that the key difference is in the
compression specifier.
The two different command lines were:
ffmpeg -i ydxj0020.mp4 -vf scale=-1:1080 -crf 21 -preset slow -c:a copy smaller7-21.mp4 // doesn't work
ie the "-crf" parameter "21" didn't work
"22" Works
Not sure what this means but it seems like a good clue
Thanks!
Contact:
Post by steve » Fri Jun 01, 2018 8:42 am
GreyCoder wrote:Not sure what this means but it seems like a good clue
Documentation for FFmpeg is here: https://ffmpeg.org/ffmpeg.html
GreyCoder
Post by GreyCoder » Fri Jun 01, 2018 2:07 pm
Thanks, I had already googled to that link
What I meant was, I don't know why such a small difference in the value ("21" vs "22") would
cause the issue (Audacity not loading audio from MP4 file correctly)
Before I made the post I had experimented with various compression specifiers. So far, it appears that
on my test file:
any value <= 21 fails
any value >= 22 works
FFmpeg uses a default value of "23" (according to my reading of the documentation).
Apparently there's more involved than just the compression specifier, since I haven't found
a YouTube video that works (yet).
Here's a non-working example from YouTube. I
"The Good- the Bad and the Ugly Theme"
https://www.youtube.com/watch?v=h1PfrmCGFnk
If someone has a link to a working YouTube video, I'd be happy to test in on my system
Thanks
DVDdoug
Forum Crew
Post by DVDdoug » Fri Jun 01, 2018 10:10 pm
I downloaded The Good, The Bad, and The Ugly with ClipGrab and it opened fine in Audacity (with the default FFmpeg installation).
Contact:
Post by steve » Sat Jun 02, 2018 12:03 pm
Worked fine for me with 1-Click YouTube Video Download.
GreyCoder
Post by GreyCoder » Sat Jun 02, 2018 3:16 pm
Thanks for posting!
Yes indeed I used ClipGrab and the MP4 file doesn't work on my installation! So somehow I screwed up the installation of Audacity/FFmepg...that's progress, 1,001 failures (apparently on my part) at a time!
Thanks again everybody for their responses, now that I have a known test case, that works for other ppl but not me, I can try various installation permutations until I to can have success...
Thanks again, having a know test case that works is very important, now I can spin my wheels trying to find out what I did wrong...
I assume Windows 8.1 is good for this? I'd hate to chase boogies that work on win 10 but not on win 8.1...
thanks again
