Truncate Silence Processing Time
Nightside
Operating System: Windows 7
Post by Nightside » Sat May 26, 2018 2:04 am
Trying to Truncate Silence on a 5hour recording. So far is has been 25hours "Applying Truncate Silence" and the "Remaining Time" says 10 hours to go.
I am not using the computer for anything else. It has an Intel Core i5-2400 cpu @ 3.10GHz, 8GB Ram, 64-bit Windows 7 Pro.
Audacity 2.2.2, I can't post jpg files?
audacity truncate.jpg (124.02 KiB) Viewed 251 times
why so slow??
Re: Truncate Silence Processing Time
Post by steve » Mon May 28, 2018 10:10 am
Are you running out of disk space?
Has the project been saved? If it has, then check the available space on the drive where the project is saved. If the project has not been saved, check the available space on the system drive.
waxcylinder
Post by waxcylinder » Mon May 28, 2018 3:07 pm
Running 2.2.2 on my W10 laptop with SSD - I ran Truncate Silence on a 5 hour project and it ran in about 25 seconds :?
Nightside
Post by Nightside » Fri Jun 01, 2018 12:46 pm
steve wrote:Are you running out of disk space?
100 GB free on my C drive. Project has not been saved. It finished after 50 hours. Any thoughts? i am doing several of these 5 hour recordings, and each one is taking longer than the last.
Post by steve » Fri Jun 01, 2018 6:30 pm
What settings are you using in Truncate Silence?
Nightside
Post by Nightside » Sun Jun 10, 2018 11:14 am
-50dB, duration: .001, Truncate to: 0 secconds
Post by steve » Sun Jun 10, 2018 5:35 pm
Nightside wrote:duration: .001
That will be why it is slow. The effect is having to analyze 18 million tiny chunks of audio (1 ms into 5 hours).
